pgjscottieuk
Feb 14, 2017Guide
Backup of RN516 to External HDD EXT4 or NTFS
My readynas 516 has NFS enabled as all my files are large 5-35GB movie files when configuring the backup in NAS frontview the suggested format is EXT4 will this not cause a problem if i ever need to ...
- Feb 22, 2017
Hi pgjscottieuk,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
FramerV
Feb 18, 2017NETGEAR Employee Retired
Hi pgjscottieuk,
NFS is a file sharing protocol and NTFS is a file system.
Here is a link describing file sharing protocols supported by the ReadyNAS.
What file-sharing protocols are supported by ReadyNAS OS 6 storage system?
FramerV
Feb 22, 2017NETGEAR Employee Retired
Hi pgjscottieuk,
