pgjscottieuk
Feb 14, 2017Guide
Backup of RN516 to External HDD EXT4 or NTFS
My readynas 516 has NFS enabled as all my files are large 5-35GB movie files when configuring the backup in NAS frontview the suggested format is EXT4 will this not cause a problem if i ever need to ...
- Feb 21, 2017
Hi pgjscottieuk,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Feb 23, 2017Guru - Experienced User
funglenn wrote:
The Readynas uses an EXT4 format
The internal drives in the RN516 use the BTRFS file system, not EXT4.
A USB backup drive can be formatted as BTRFS, FAT32, NTFS or EXT4 (http://kb.netgear.com/7009/ReadyNAS-OS-6-USB-Port-use?cid=wmt_netgear_organic)
I recommend using a format that you can read on other systems you have. FAT32 has a file size limit of 2 GB, so it is probably not the best choice. You can connect the USB drive to a PC (windows or OSX) instead of directly to the NAS, and back up the NAS over the network. If you have a mac, that allows you to use any OSX format, and on both types of PCs allows you to encrypt the backup disks.
pgjscottieuk
Feb 23, 2017Guide
So really the two choices sensibly are NTFS or EXT4 Netgear recommend the Nas Backup is in EXT4
I assume that if my Nas got into trouble i carry one spare new drive but if i lost two and lost data then once the faulty drives had been replaced one would reinstate the Nas from the backup.In what circumstances would i want to access the backup drive as its pure purpose is a backup for the Nas an expense i didnt really want to go to but as my movie library grows there is an awfull lot of hours days work putting it all back and as you all keep saying you need a backup apart from your nas.
If i had know all of this from the beggining i would have set up the nas in raid 1 but to do that i guess i would have needed to install 6 drives all at once or could i have done it 2 at a time ?
Sorry i forgot to say the only data on the Nas are movies for streaming using plex i use Mac and windows Mac for transcoding and a windows Htpc for running the show which is a i7 quad core 4ghz 16 gb ram etc the mac is a mac pro 6 core 3.5ghz which unfortunately cant not passthrough DTS-HD MA or truehd which is why i had the htps built i must admit having a USB drive attached to nas could have drawback in as much as if someone broke in and stole the nas they would probably steel the back up drive as well
So if the backup drive was attached to the mac when setting up the backup job and click on browse how do you find the backup drive attached to the mac
- StephenBFeb 23, 2017Guru - Experienced User
No matter what Netgear recommends, a backup you can't read on other systems isn't useful.
NTFS is widely supported (and there are some inexpensive packages for OSX that add write support).
If you can read EXT or BTRFS on other systems, then those are also good choices.
I agree with your assessment, and I do back up my media library for that reason. RAID isn't enough to keep your data safe - and there other other possibilities than disk failures.
There are other RAID options (RAID-6 and RAID-10) which have more redundancy than the default RAID-5. But you'd still need a backup. For most home users the combination of RAID-5 and backup is cost effective - and is a better choice than no backup with RAID-6, RAID-10, or multiple RAID-1 volumes).
There are a couple other similar threats - a lightning strike, small fire or flooding could also take out both the NAS and the backup.
One option is to augment a local backup with cloud backup. There are several options for cloud backup - personally I've been using crashplan for some years. You could potentially install it on your Mac (and it can be set up to backup your NAS shares). Cloud backup does need a reasonably fast internet uplink (with no upload limits).
Another is to make a second USB backup, and store the disk(s) of the second one somewhere else - a safety deposit box, or perhaps exchange backups with a trusted friend.
BTW, there are several cloud offerings that do sync (amazon, dropbox, ...). But sync is not the same as backup. If you accidentally delete your media (either on the NAS or in the cloud), the sync will propagate the deletion - which is not what you want in a backup solution.
I'm not a mac owner, so I can only give general guidance.
One option is that you can share the USB drive on the mac, and then the normal backup jobs on the NAS can be set up to use the USB drive as a destination.
Though that is possible (and some do it that way), personally I think it is better to use a utility that runs on the mac to copy the files from the NAS. Ideally you'd have a copy utility that can verify, and which supports incremental updates. With Windows you use teracopy or robocopy (and several other choices). But I can't give a similar recommendation for the mac, since I don't own one.
- pgjscottieukFeb 23, 2017Guide
Just ordered 16TB My Book Duo will format to NTFS that should keep me going for a while chew over setting up connected to mac pro perhaps report back when done hopefully this will have helped some mac users as we can find support a bit thin on the ground
StephenB wrote:
pgjscottieuk wrote:So really the two choices sensibly are NTFS or EXT4 Netgear recommend the Nas Backup is in EXT4
pgjscottieuk wrote:as my movie library grows there is an awfull lot of hours days work putting it all back and as you all keep saying you need a backup apart from your nas.
pgjscottieuk wrote:If i had know all of this from the beggining i would have set up the nas in raid 1 but to do that i guess i would have needed to install 6 drives all at once or could i have done it 2 at a time ?
pgjscottieuk wrote:i must admit having a USB drive attached to nas could have drawback in as much as if someone broke in and stole the nas they would probably steel the back up drive as well
pgjscottieuk wrote:So if the backup drive was attached to the mac when setting up the backup job and click on browse how do you find the backup drive attached to the mac
Just ordered 16TB My Book Duo will format to NTFS that should keep me going for a while chew over setting up connected to mac pro perhaps report back when done hopefully this will have helped some mac users as we can find support a bit thin on the ground- pgjscottieukFeb 24, 2017Guide
Paragon NTFS for mac inexpensive for read write also Paragon ExtFS for mac
