Gearmeister's avatar
Gearmeister
Backup ReadyNas 214 to External Drive
I'd like to back up my ReadyNAS 214 and its current contents.  The shares have both Windows and Mac files on them.  I understand that things can go south quickly when formats mistmatch.  So, if i buy a target back up drive, which format should i use?  NTFS, MacOS, some other format?  The goal is if I have a catastrophic failure on the ReadyNas 214, I'd have a back up to the backup.  Any guidance would be greatly appreciated.
Model: RN21400|ReadyNAS 214 Series 4- Bay (Diskless)
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Gearmeister
    Welcome to the Community!
    Since you both have Windows and Mac OS I would go with the FS that you will be able to access on different systems. I think the best option would be to go with NTFS.
    While it is mainly for Windows, I think Mac OS provides support already. Also, if you can setup a different external for MacOS then that would be best.
    HTH
    Regards
    • StephenB's avatar
      The Mac does have built-in read support for NTFS, so I agree that is the best format for the backups.
      There are some third party packages that can add write support (Paragon being one).
      • Sandshark's avatar
        Sandshark
        Sensei
        If your desire is to restore the NAS from the backup, then EXT4 would be best.  But if you may need to get a file directly from the drive to the Windows or Mac system, then NTFS.
ProSupport for Business
