chrisb691
Feb 21, 2019Aspirant
Backup to NAS fills local drive
I have my NAS connected to my router, and backup my laptop to it via a wireless connection to the router. I have a share setup as a mapped drive on the laptop. The backups complete successfully, but ...
chrisb691
Feb 22, 2019Aspirant
Thanks Stephen,
Offline files was already disabled, so that's not it.
Feb 22, 2019Guru - Experienced User
Well, C:\owner\appdata\roaming\microsoft\windows\network shortcuts is empty on my Win10 PCs. I also use Acronis TrueImage to back them up to the NAS.
What version of Windows are you using?
Have you checked the NAS to make sure that Acronis is backing up to the NAS?
- chrisb691Feb 22, 2019Aspirant
Hi Stephen,
I am on windows 10, and the NAS is definitely getting the backups. Are you backing up via wireless, or cable connection to the NAS?
