brannodz
Oct 29, 2016Aspirant
Basic Use of ReadyNAS
OK, got new Firmware (6.5), and have whole house hardwired. I orginally thought that I could use the ReadyNAS as the primary hard drive for storing family photos, videos, and docs. I'm finding ...
brannodz
Oct 30, 2016Aspirant
Framer, thanks for the thoughts. I'll start with mapping then review your link. Thanks again!
Sandshark
Oct 30, 2016Sensei
Unfortunately, there are still some programs around that will not show mapped drives in the open/save dialogs. Hopefully, you don't run into any.
If you do, using a symbolic link instead of drive mapping can be a solution. From a Windows command prompt, type mklink /? for the help on symbolic links.
Also remember that putting all your eggs in one basket makes a failure all the more costly, so make sure you have a backup method in place. A RAID device is a big step toward more reliability, but failures and physical loss can still occur.
- brannodzNov 08, 2016Aspirant
Thanks for the insight here people. Good follow-up via email also.
I think my basic understnading was off. So "mapping" the drive treats the ReadyNAS as a hard drive. You can get read only access from the ready cloud APP. I'll play around with it, but SandShark, I do have the RAID up i think but definatey will keep a USB backup offsite.
Dave
- JBDragon1Nov 11, 2016Virtuoso
Yes mapping the HDD will basically make it look like any HDD directly connected to your computer, with a assigned drive letter of your choosing. So while Windows is on C: Your NAS could be on R: like I have my NAS set to, or basically any letter you don't use. Then you can also Name it whatever you want like like any other HDD. You can read/write like anything else for most all programs.
The only program I used that Mapping didn't work was when I was running SONARR on my Windows computer and having it accessing the NAS.
- StephenBNov 11, 2016Guru - Experienced User
JBDragon1 wrote:
... The only program I used that Mapping didn't work was when I was running SONARR on my Windows computer and having it accessing the NAS.
FWIW, SONARR does handle that now, my Win 10 desktop has SONARR installed, with my Pro data volume mapped to a drive letter.
