joe_wht
Apr 02, 2016Luminary
Benifit ? ReadyNAS 214 Ethernet Port Aggregation to NightHawk 8500 ?
New ReadyNAS 214 & Netgear Nighthawk 8500 Router Will I benifit from Port Aggregation ?? Note: I have 100% ( ALL ) of my content on my ReadyNAS and my wired Laptop, Wired Desktop, pulling and...
- Apr 02, 2016
If you have more than one gigabit ethernet user connected to the router (not via a switch) using the NAS simultaneously, then you might. But most users will not.
WiFi connections by themselves won't generate enough traffic. I see between 200-300 mbits download speeds from a nearby room (30-40 feet from the router).
On the other hand it does on harm to use it (unless you need the extra LAN port).
Apr 02, 2016Guru - Experienced User
