BobFord
Apr 05, 2018Aspirant
Best Expansion Unit for Netgear NAS
I have an RN628X unit and am looking to put an expansion unit to take at least 5 HDD's (3.5" SATA).
What is the panels view of best options?
TVMIA
Bob
Thanks all for the comments - much appreciated
I think short term, I'll go for the multi-bit and then look to expand the NAS suite in due course
- Marc_VNETGEAR Employee Retired
- BobFordAspirant
Thanks Marc
All search results in the UK are showing as this device is discontinued.
Are there other units that users herein would recommend?
- mdgm-ntgrNETGEAR Employee Retired
Adding a second NAS unit to your network would add better performance than an expansion unit and expansion units should have a separate data volume anyway.
You could add a RN426, RN428, RN526X, RN528X, RN626X or RN628X to your network.
