chemnitzer
Jul 27, 2015Follower
Betreff: ReadyNAS OS 6.2.3 now available
Hallo is ReadyNAS OS 6.2.3 for ReadyNas NV+ (RND4250) or NOT ? Thank you for reply.
DaneA
Jul 27, 2015NETGEAR Employee Retired
Hi chemnitzer,
In addition to the response of mdgm, if ever you have an NV+ v1, here is the link below where you can download the 4.1.15 beta firmware:
DaneA
Netgear Community Team
- StephenBJul 27, 2015Guru - Experienced User
There are some security patches in 4.1.15 beta, so I do recommend that you install it.
Though it is beta, I've been running it for several months and have found it to be stable.
