Petarc
May 14, 2013Aspirant
Billion 7800VDPX & ReadyNAS Duo connectivity issues
Last week I setup my new Billion 7800VDPX – everything works as it should except being able to connect to the Netgear ReadyNAS Duo. When I connect it all up and launch the RAIDar app it does not fi...
May 15, 2013Guru - Experienced User
(a) is the new router still using 10.1.1.x IP addresses, or it is using something else?
(b) Is the gateway address assigned to the duo the internal IP address of the router (frontview, network->global interfaces)?
(c) can you ping the NAS?
(d) can you reach the NAS directly by entering https://10.1.1.5/admin in to your browser window?
