Petarc
May 14, 2013Aspirant
Billion 7800VDPX & ReadyNAS Duo connectivity issues
Last week I setup my new Billion 7800VDPX – everything works as it should except being able to connect to the Netgear ReadyNAS Duo. When I connect it all up and launch the RAIDar app it does not fi...
May 15, 2013Guru - Experienced User
Ok. If the billion is using 192.168.1.x addresses, then you can't use 10.1.1.5 with the NAS. It needs to be 192.168.1.x.
If you do an OS reinstall from the duo front panel (being careful not to do a factory reset!) it will change the IP to use DHCP (get it automatically). It will also change the admin password back to netgear1.
Alternatively reinstall the old modem briefly restart your PC, and then reconfigure the duo to use DHCP using frontview. Then put the new modem in place again.
If the billion allows you to reserve IP addresses, then that is a better way to get a stable IP address than manually assignment in the duo. Basically, the duo gets the address automatically, but the router always assigns the same one. That avoids this kind of problem.
