gpwolfe
Nov 30, 2010Aspirant
Boo-Yah! 8GB (2x4GB) works in pro.
Greetings, I just wanted to say that the pro (rndp6000) works w/4GB DIMMs. Specifically, at least, these: DDR2 8GB (2x4GB) PC6400 800MHz PATRIOT PSD28G800K Frontview shows: Firmware: RAID...
gpwolfe
mdgm wrote:
TeknoJnky wrote:
glad to hear 8gb works, I'd love to have that in my pro along with some vbox VM's
But doesn't the Pro only work with 32-bit VMs as it doesn't have a processor with VT-x support?
Sure using something like Virtual Box is a logical reason for why someone might want 8GB of RAM in a ReadyNAS, but if you can't run 64-bit VMs then you'd need to have multiple 32-bit VMs you want to run.
That's what an E6600 or E6700 Core 2 Duo is for. :) Those are the latest and greatest that will work in the pro that have VT-x support...on top of being less anemic than the E2160 anyway.
--Gary
