gpwolfe
Nov 30, 2010Aspirant
Boo-Yah! 8GB (2x4GB) works in pro.
Greetings, I just wanted to say that the pro (rndp6000) works w/4GB DIMMs. Specifically, at least, these: DDR2 8GB (2x4GB) PC6400 800MHz PATRIOT PSD28G800K Frontview shows: Firmware: RAID...
fbmachines
Nov 30, 2010Guide
mdgm wrote: There are two versions of the CPU used in the new Pro 6. One of them supports VT-x. If you get a Pro 6 and it has a CPU supporting VT-x that would be a better option imo. If you can put 8GB RAM in a Pro you should be able to do the same in a Pro 6.
I can confirm that the E5300 CPU in my Pro-6 beta unit does support VT-x...
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 23
model name : Pentium(R) Dual-Core CPU E5300 @ 2.60GHz
stepping : 10
cpu MHz : 2593.861
cache size : 2048 KB
physical id : 0
siblings : 2
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx lm constant_tsc arch_perfmon pebs bts rep_good aperfmperf pni dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm xsave lahf_lm tpr_shadow vnmi flexpriority
bogomips : 5187.72
clflush size : 64
cache_alignment : 64
address sizes : 36 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 23
stepping : 10
cpu MHz : 2593.861
physical id : 0
siblings : 2
core id : 1
cpu cores : 2
apicid : 1
initial apicid : 1
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bogomips : 5186.72
clflush size : 64
power management:
