gpwolfe
Nov 30, 2010Aspirant
Boo-Yah! 8GB (2x4GB) works in pro.
Greetings, I just wanted to say that the pro (rndp6000) works w/4GB DIMMs. Specifically, at least, these: DDR2 8GB (2x4GB) PC6400 800MHz PATRIOT PSD28G800K Frontview shows: Firmware: RAID...
jmirabil
Oct 08, 2011Aspirant
fbmachines wrote:
spiderman wrote: As I will be purchasing a new diskless Readynas Pro 6 shortly, can those who have posted on this thread confirm that the following ram will
work on this unit:
Patriot Signature 4GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model PSD24G8002
That's the model that I use and it has been running great. I haven't tried running just one stick though. Is that what you plan to do?
If so, I can remove 1 stick and give it a whirl.
SUCESS REPORT:
I can report on my Pro Business Readynas I just completed a 4-->8Gb Readynas changeover in RAM, and I noticed my NAS with WD30EZRS drives is a bit snappier with 8Gb than 4Gb. I used two of the PSD24G8002 Patriot memory sticks like above... I had two 2Gb Adata blue memory modules in there with aluminum shields from Egghead before, I might try those memory sticks in my buddy's Readynas Ultra 6 w/ low power Atom dualcore processor.
I too would like to try running ESXi datastores and the Java VM Virtual Box on my Readynas pro business and use my PRO as a multi-media file server, probably a Conroe 2.4Ghz dualcore upgrade (E6600) from the E2160 might help also, but dont want to violate my warranty... Any advice for virtualbox or ESXi? I'd love to know here or via a PM. Thanks!
