gpwolfe
Nov 30, 2010Aspirant
Boo-Yah! 8GB (2x4GB) works in pro.
Greetings, I just wanted to say that the pro (rndp6000) works w/4GB DIMMs. Specifically, at least, these: DDR2 8GB (2x4GB) PC6400 800MHz PATRIOT PSD28G800K Frontview shows: Firmware: RAID...
mdgm-ntgr
Oct 08, 2011NETGEAR Employee Retired
The Pro Business (RNDP6000-100) has a CPU that doesn't have VT-x so you can't run 64-bit VMs using VirtualBox. You can use it as an ESXi datastore for 64-bit VMs though.
3rd party memory upgrades are not supported, neither is installing stuff like VirtualBox.
CPU upgrades do void the warranty and not all work (can be incompatible or cause overheating etc.). If you want to try a CPU upgrade search for CPU upgrades that others have done). Instead of doing a CPU upgrade it would be much better to sell a Pro Business (RNDP6000-100) and get a Pro 6 (RNDP6000-200).
