gpwolfe
Nov 30, 2010Aspirant
Boo-Yah! 8GB (2x4GB) works in pro.
Greetings, I just wanted to say that the pro (rndp6000) works w/4GB DIMMs. Specifically, at least, these: DDR2 8GB (2x4GB) PC6400 800MHz PATRIOT PSD28G800K Frontview shows: Firmware: RAID...
TeknoJnky
Feb 02, 2012Hero
If you already have a pro 6, the easiest way to find out what ram is already in the device (google the part number or whatever is printed on the dimm), then google for the same or similar in the size you want.
