gpwolfe
Nov 30, 2010Aspirant
Boo-Yah! 8GB (2x4GB) works in pro.
Greetings, I just wanted to say that the pro (rndp6000) works w/4GB DIMMs. Specifically, at least, these: DDR2 8GB (2x4GB) PC6400 800MHz PATRIOT PSD28G800K Frontview shows: Firmware: RAID...
chirpa
Dec 26, 2013Luminary
Likely those modules are not compatible. If it doesnt get past the logo, the memory test won't even work (failed to POST). Does it boot with one stick installed?
