ziemowit
Jul 26, 2024Aspirant
BTRFS read-only state, OS 6.8.10, ReadyNAS Ultra 4
Hello, everybody! It seems like I have met the same problem as a few other people here, namely BTRFS becoming read-only. Background Machine is Ultra 4, with 2GB memory, converted to run OS6. Capac...
Sandshark
Jul 26, 2024Sensei
A hard re-boot while the NAS is actively writing files can damage the BTRFS volume, so you likely did this to yourself. There is noting innately different with the Ultra that would cause this. When a volume is damaged, the NAS often puts it in read-only mode to prevent you from making matters worse.
Do not reboot again until your backup is up to date. Doing so will not fix your problem and may result in the volume failing to mount.
The only guaranteed fix is it destroy and re-create the volume or do a complete factory default. Note that if you have apps loaded, that can be problematic since the apps are on the data volume. So un-install them and re-install after you've re-created the volume or see here: How-to-save-your-apps-when-destroying-your-main-volume-OS6 .
As for drives, just avoid any that are SMR.
ziemowit
Jul 27, 2024Aspirant
Hello, Sandshark! THANKS for the answer. 🙂
I noticed that while I was writing Stephen B also answered with some more information. Thanks, Stephen, I will read and see what I can understand of it.
OK, I get it. 🙂 I was probably a bit too impatient with the power off. Well, you never cease learning; I thought - correct or wrong - that a NAS would and should survive an unexpected power off. I was wrong and stand corrected. Guilty as charged.
The curious and "funny" thing is that it seems like I cannot even do "ls" on my /data directory (I/O error), but I can access /data/Pictures without problems, while /data/Videos gives me I/O error. Nevertheless, I have full backups of stuff.
As far as installed applications go, it is not a problem either, as I have downloaded the binaries long time ago and actually only use ssh and possibly MySQL with PHP.
