cbr600
Jul 08, 2011Aspirant
Can an XRAID-2 with dual redundancy be expanded?
Hi If I have 4 Hard drives in XRaid-2 with dual redundancy in a Readyans Pro 6. Can I auto expand it later with another two discs, if I only want to buy 4 dicsc now?? ( so I have 4 usable discs a...
mdgm-ntgr
Jul 08, 2011NETGEAR Employee Retired
Yes. Then when all drive bays are full you can replace at least four disks with higher capacity disks (one disk at a time of course) to expand it even further.
