cbr600
Jul 08, 2011Aspirant
Can an XRAID-2 with dual redundancy be expanded?
Hi If I have 4 Hard drives in XRaid-2 with dual redundancy in a Readyans Pro 6. Can I auto expand it later with another two discs, if I only want to buy 4 dicsc now?? ( so I have 4 usable discs a...
cbr600
Jul 17, 2011Aspirant
Thanks,
So just making sure I have this correct. If I have a 4 disk dual redundancy xraid 2 setup then later I buy 2 disks, and i can just put them the unit and it auto expands. I dont have to backup my data and factory reset to increase the array?
Cheers
Cheers
