cbr600
Jul 08, 2011Aspirant
Can an XRAID-2 with dual redundancy be expanded?
Hi If I have 4 Hard drives in XRaid-2 with dual redundancy in a Readyans Pro 6. Can I auto expand it later with another two discs, if I only want to buy 4 dicsc now?? ( so I have 4 usable discs a...
mdgm-ntgr
Jul 18, 2011NETGEAR Employee Retired
Yes. If this will make it clearer you may wish to take a look at X-RAID2 dual-redundancy expansion paths, an excellent post by Jedi Knight (do note that this was written before converting from single to dual-redundancy without a factory reset was made possible, so it doesn't allow for that, though this isn't relevant to your situation).
