cbr600
Jul 08, 2011Aspirant
Can an XRAID-2 with dual redundancy be expanded?
Hi If I have 4 Hard drives in XRaid-2 with dual redundancy in a Readyans Pro 6. Can I auto expand it later with another two discs, if I only want to buy 4 dicsc now?? ( so I have 4 usable discs a...
mdgm-ntgr
Jul 18, 2011NETGEAR Employee Retired
Great!
Since this is a new setup, I would put one disk in the NAS, update to latest RAIDiator (currently 4.2.17: http://www.readynas.com/RAIDiator_x86_4_2_17_Notes), then power down, put all the disks in and do a factory reset using the boot menu (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu), discover the NAS using RAIDar (http://www.readynas.com/downloads) during the 10 minute countdown and select X-RAID2 and check the dual-redundancy option, then confirm your selection. This will give you a clean setup on the latest firmware using X-RAID2 dual-redundancy.
