cbr600
Jul 08, 2011Aspirant
Can an XRAID-2 with dual redundancy be expanded?
Hi If I have 4 Hard drives in XRaid-2 with dual redundancy in a Readyans Pro 6. Can I auto expand it later with another two discs, if I only want to buy 4 dicsc now?? ( so I have 4 usable discs a...
cbr600
Jul 18, 2011Aspirant
Thanks.
I have the ReadyNas Pro6 Diskless in my hands now, but before I run it up, how can I check it is a Version2?
They said it was but there are no markings on the box re version 2
The part number says RNDP6000-200AJS
Cheers
Cheers
