cbr600
Jul 08, 2011Aspirant
Can an XRAID-2 with dual redundancy be expanded?
Hi If I have 4 Hard drives in XRaid-2 with dual redundancy in a Readyans Pro 6. Can I auto expand it later with another two discs, if I only want to buy 4 dicsc now?? ( so I have 4 usable discs a...
cbr600
Jul 18, 2011Aspirant
Ahr thanks, that's the info I was after as I was not sure if any V1's were left in the supply chain etc.
I would like it to be visable somewhere in the admin UI though,
Anyway have flashed the latest FW, sees the 3TB drives and syncing the array now.(5hrs for 12TB.)
Thanks for your help.
