SadNation
Jan 21, 2023Tutor
Can I backup from an onsite ReadyNAS to another offsite ReadyNAS?
Hi all I am the proud owner of two ReadyNAS systems. My work one is a RN-104 with 22TB and my home one is a RN-626X with 72TB. Is there any way of automatically backing up data from one system to...
SadNation
Jan 21, 2023Tutor
Hi, thanks for the reply.
With Zerotier, does this mean once I have set up the connection from one location to the next that I can just use something like Aomei Backupper on the PC to automate the backup from one NAS to another NAS?
Sad Nation
Jan 22, 2023Guru - Experienced User
The advantage of ZeroTier in this case is that it allows you to set up both NAS on the ZeroTier network, so they can communicate directly. You would then use the incremental rsync jobs built into OS-6 to back up the desired NAS shares to the other NAS. These can be run automatically on a schedule.
If you can connect a PC to an existing work VPN, then you could use a PC backup program w/o using ZeroTier.
- SadNationJan 22, 2023Tutor
Thanks for the reply StephenB.
Okay, I have set up ZeroTier so that I an see my work computer and my home computer as part of my two networks with full control on each which is cool.
How do I set up ZeroTier on each NAS as that is not at all clear? There is not a built-in app so there must be another way.
I just found this link so I am trying this now.
Setting up ZeroTier to work with your NAS - NETGEAR CommunitiesThanks for your help so far!
Hi all
Yes that worked and I can backup from one NAS to another without any computer being involved.
What is the best way to only backup new files (incremental) rather than everything? Should I use File Backup and over what protocol? Or is ReadyDR a better bet? Is there a way to compress the data so it takes up less space? So many questions!
