niallryan
Jul 16, 2024Guide
Can I connect directly my MacBook Pro to NAS
Hi all,
I am looking to see if it is possible to connect my MacBook Pro directly to my ReadyNAS Ultra 6 which would allow me to transfer TB's of files quickly rather than going through the network.
I would have a larger drive station connected directly to my Mac so basically transferring from NAS to large external Hard Drive via my MacBook Pro.
Any help would be greatly appreciated as always.
Regards
N
The only way to connect to the Ultra is using ethernet. It is possible to set up a direct connection to the MacBook using one of the two ethernet ports on the MacBook. But it won't be any faster, so IMO not worth the trouble.
What speeds are you seeing for large file transfers? I don't own this model, but I think large-file transfer speeds should be in the 60-70 MB/s range.
Many thanks for coming back to me. Unfortunately if I was getting even half that I would be over the moon.
Currently getting around 5mb/s as the network is a busy network with everyone of the family on the network, hence why I was hoping to take the NAS off the network and have it directly connected to the MBP and transfer to the larger disk.
Regards
N
- Can you explain your network setup?
- Is the Macbook connected using wifi or ethernet?
- Is the only device that uses the NAS the MacBook? Other PCs, phones/tablets (perhaps using DLNA)?
- saudadeApprentice
My apologies for butting in...
Is this a "one time" deal or will you need to do this on a recurring basis?
If the destination is the USB drive, why not connect it to the NAS USB Port and run a backup job (or several) right to the USB? Even if it's only a 2.0 port, it won't incur any network traffic, won't tie up your Macbook and keep a log. Yes, it may take a while but it's another alternative.
Am I missing something here?
Another option (whether one-time or recurring) is to move the NAS to the MacBook location, and connect the NAS and the MacBook to the home network with a gigabit switch. The traffic between the NAS and the MacBook will only go through the switch, so it would avoid whatever congestion points are on the home network.
But if niallryan is seeing 5 mbps large file transfer speeds on his ethernet, then there is something wrong with the ethernet fabric that really should be fixed.
5 mpbs on wifi might just be a range issue, in which case deploying a mesh (or traditional APs) would be needed.
Agreed on the bigger picture that I definitely need to check all cabling afaik there is a mixture of Cat5 and Cat6e all over the house. Also the NAS's are all stored in the games room at the end of the garden which is approx. 20 - 30 meters away from the house. I do have an outdoor cable (Cat 6e) running from the router in the house to the 16 port switch in the games room. There is also an outdoor cable running under ground from the games room to the house (this was the original cabling when the games room was being built) and I believe this is Cat5/5e - so I shall investigate to ensure that that cable is not connected to anything on the network otherwise that would be a conflict straight off.
A lot of the cables are cat 5e which are running form switches to hubs and devices where necessary.
The hubs are actual 3rd party hubs for HomeKit eg, a hub for the central heating, 2 hubs for the security cameras, 2 hubs for the hue lighting, a hub for all my lights and sockets (Lightwaverf) - all necessary I'm afraid.
The only hiccup I do have is that the wifi in the games room is not part of the wifi mesh. The games room wifi runs from an Apple AirPort Express which is wired to the switch in the games room. I do plan on getting another Deco to replace that at some stage.
I appreciate all the help being received all round.
Regards
N
Hi there and no problem in joining in. This would be a one off as I am transferring all data from all 4 x ReadyNAS's to a single Disk Station which has 3 x 24tb hdd's (I may have falling short on the explanation - apologies).
Regards
N
