niallryan
Jul 16, 2024Guide
Can I connect directly my MacBook Pro to NAS
Hi all, I am looking to see if it is possible to connect my MacBook Pro directly to my ReadyNAS Ultra 6 which would allow me to transfer TB's of files quickly rather than going through the network. ...
Jul 16, 2024Guru - Experienced User
niallryan wrote:
Many thanks for coming back to me. Unfortunately if I was getting even half that I would be over the moon.
Currently getting around 5mb/s as the network is a busy network with everyone of the family on the network, hence why I was hoping to take the NAS off the network and have it directly connected to the MBP and transfer to the larger disk.
- Can you explain your network setup?
- Is the Macbook connected using wifi or ethernet?
- Is the only device that uses the NAS the MacBook? Other PCs, phones/tablets (perhaps using DLNA)?
niallryan
Jul 18, 2024Guide
Many thanks again for the reply.
My network !! I shall try, lol
I have my 4 netgear NAS's in a room at the end of the garden connected to a tp-link gigabit 16-port switch. I access the NAS either on my Mac mini (M2) via ethernet in my office in the house which is connected to another 16 port gigabit switch or I use my MBP laptop using wifi to connect.
I use either or to connect to the NAS's
I also have some video, music files on the NAS's to which family would connect using devices to watch these all the time.
So there would be traffic on the network as I also have HomeKit running throughout the house with HomePods in every room and apple tv's etc etc (Just giving you a small picture of the usage and setup.) Everything is automated including the security cameras and other sensors.
Overall there are 2 x 16 port gigabit switches, 3 x 8-port gigabit switches, 2 x 5-port gigabit switches, 6 hubs and the router and using 1gb fibre broadband. Mostly Cat5 cable but there are now some cat6 cabling slowly installing.
Hope this helps. I have also found articles about 'rclone' which may be something I could use to transfer and believe it can be installed on the readynas but unsure where it gets installed.
Regards
N
- StephenBJul 18, 2024Guru - Experienced User
Overall there are 2 x 16 port gigabit switches, 3 x 8-port gigabit switches, 2 x 5-port gigabit switches, 6 hubs and the router and using 1gb fibre broadband. Mostly Cat5 cable but there are now some cat6 cabling slowly installing.Let's start with the ethernet.
Most modern gigabit switches are non-blocking. That means that the switching backplane inside the switch is sized so it can deliver 1 gpbs full duplex on every port simultaneously.
That suggests that the likely bottlenecks are the cat5 cables and the "hubs".
- Pure cat-5 cable is rated at 100 mbps ("fast ethernet" and not gigabit. A short patch cable might be able to carry 1 gigabit - it depends on how the cable is constructed. Cat-5e can carry gigabit. So my first suggestion is to double-check the cat-5 cables, and see which ones are actually Cat-5e. Expedite replacing the pure cat-5 cables, particularly ones the run in between switches, and on the path between the ReadyNAS systems and the Macbook.
- Can you give more detail on the "hubs" - manufacturer/model, and why you need them? Ethernet hubs will certainly degrade your network performance, so if that is what they are you should remove them (replacing them with switches if you need the ports). If they are creating a wifi mesh network, then of course that is a different story.
In your case the connection between the switches is also gigabit, so the total bandwidth between your switches is limited to 1 gigabit in each direction. That limitation doesn't explain your slow network speeds. But you might get somewhat better performance if you were able to reduce the number of switches. Just something to consider for the future (after you deal with the cat5 and perhaps the hubs).
niallryan wrote:
Overall there are 2 x 16 port gigabit switches, 3 x 8-port gigabit switches, 2 x 5-port gigabit switches, 6 hubs and the router and using 1gb fibre broadband. Mostly Cat5 cable but there are now some cat6 cabling slowly installing.So the router is the only wifi access point?
niallryan wrote:
Hope this helps. I have also found articles about 'rclone' which may be something I could use to transfer and believe it can be installed on the readynas but unsure where it gets installed.I don't see how rclone would help your situation. One reason is that I believe MacBooks already have rsync installed, so you could just use that.
But the bigger reason is that neither will give you significantly faster transfer speeds.
- niallryanJul 19, 2024Guide
Many thanks again for responding to my problem and apologies for the delay in coming back to you.
So the router is the only wifi access point?Sorry, I should have stated that I am not using the wifi from the router as that is turned off as I am using the wifi mesh from my Deco's
On Speed test around the house I get approx. 800 - 900mb and at worst would be around the 400mb.
Regards
N
