tychocaine
Jun 24, 2014Aspirant
Can I mix disks in a raid set
I have 12 2TB disks in a X-RAID2 set in my ReadyNAS 4200 and one has just failed. The disks are Hitachi HUA722020ALA330 units. Ideally I'd like to replace with an identical unit but I can't find any a...
Jun 25, 2014Guru - Experienced User
It isn't on the HCL- if the unit is still under warranty that could be a concern.
It likely would work, though I don't see any posts in the forum from people using that model.
