SisyphusBond
Oct 12, 2015Aspirant
Can I move my hard drive from a RN102 to a RN312 and keep all the contents?
I'm not sure if the title is quite clear on what I mean, but I didn't want to get too wordy. I've got a RN102 with a 4TB drive in that is fairly full (about 75%). I've just bought a RN312 as an u...
SisyphusBond
Oct 18, 2015Aspirant
StephenB wrote:
SisyphusBond wrote:I had another thought. Could it be because I'm not trying to migrate it to a pure "diskless" system? The manual only takes about migrating to a diskless NAS.
I had installed one temporary hard drive to upgrade the firmware, and then just swapped the disks. Could it perhaps be that the 312 is still expecting the temporary drive to be there somehow?
Did you power down, remove the temporary, add the original disks, and then power up?
That's exactly what I did, yes.
I tried to reinstall the OS after adding the original disk. That seems to have had some success, as the 312 now boots and I can see the files through ReadyCloud. I can't for the life of me seem to get through to it with anything on my LAN, thought.
SisyphusBond
Oct 20, 2015Aspirant
I don't suppose there any further suggestions? At the moment the only option I can see is to buy another hard drive and start afresh with the new NAS, then copy over the old files. That's £125 I didn't really want to spend just yet, though.
- StephenBOct 20, 2015Guru - Experienced User
Did you try looking at the status in RAIDar? (if it shows up, confirm the IP address).
Does it respond to ping?
- SisyphusBondOct 20, 2015Aspirant
To be honest I've now put in an order for another drive, as I was getting impatient (my kids DVDs have been ripped to a Plex Server on the NAS) and wanted to ensure delivery promptly.
I'll do my best to test your suggestion anyway though, in case it can help anyone else who might encounter the same problem.
I should add that it appears on my router's "Attached Devices" correctly as far as I can tell. It even accepts the forced IP address I set if I activate it. I just can't seem to access it with anything except network drives.
I tried accessing it with SSH via Putty too. It asks me for my password but when I put it in the terminal closes abruptly.
Was ssh enabled? You are using root for the username?
SSH was enabled, yes. Though I think I was using "admin" to log in (it's been a while since I last tried it, so I was rusty).
I'll give that a shot with "root" when I try checking it with RAIDar (probably this evening).
Okay. I've just tried both of those things. Using SSH with root worked fine, and the NAS is visible to RAIDar (both after reinstalling the OS after swapping the drives). I still can't access the admin page, or any of the apps installed (e.g. Plex, Bittorrent Sync, etc.) from the direct links I had set up.
I'm not too sure where that leaves me or if it helps. I'm not too bothered personally, as having been pushed into buying another drive I'm planning on using it when it arrives tomorrow anyway. I've no objection to running more tests in the meantime if it's liable to be of any help to others though.
I suspect the apps would be a problem - the NAS itself can migrate to x86, but the apps would remain arm. Probably we should have said to uninstall the apps first.
The apps might also be the reason the web page won't start.
- SisyphusBondOct 21, 2015Aspirant
StephenB wrote:I suspect the apps would be a problem - the NAS itself can migrate to x86, but the apps would remain arm. Probably we should have said to uninstall the apps first.
Ah. I wonder if that's it, as Plex at the very least is an ARM specific version I think.
I may give that a try today before going for the extra drive. Would it lose all the settings and so forth, though?
- StephenBOct 21, 2015Guru - Experienced User
Netgear can probably tell you how to remove the apps with ssh. Hopefully one of them will chime in.
You would lose plex settings (and the other app settings too).
StephenB wrote:Netgear can probably tell you how to remove the apps with ssh. Hopefully one of them will chime in.
I might as well give it a try to find out, given that I'm probably planning on a new drive and fresh start anyway.
- SisyphusBondOct 26, 2015Aspirant
Just as a brief update, I ran out of time to check this and the drive has now been formatted. So my apologies to anyone who comes to this thread looking for answers to a similar question, but hopefully it at leaves something worth trying if you do.
