taiya
Jan 05, 2019Aspirant
Can I upgrade CPU and memory for ReadyNAS 4312X and 528x
Hi,
I would like to know if I can upgrade the CPU and memory on the ReadyNAS 4312X and 528x .. I know the older version of 516 allows this flexibility. And the new 420 series can only upgrade the memory, not the CPU. I cannot find any info for thoe 2 models I mentioned above..
Pleaes share your experience ..
Thanks
- Marc_VNETGEAR Employee Retired
Hi taiya
Welcome to the Community!
ReadyNAS 4312X and 528X memory can be upgraded.
The 528X has 4 memory slots (Max: 64GB) and supports up to DDR4-1866. Community members might be able to provide you what to look for.
ReadyNAS 4312X can be expanded to 64GB as well using RMEM04-10000S or a U-DIMM with similar spec.
Hope this helps!
Regards
- taiyaAspirant
Hi Marc_V,
Thanks for response. it is good to hear that there are extra slot for memeory, and it can be upgrade later.
What about the CPU? It is solder in? or it can be upgrade?
I read that the older 516x's CPU can be upgraded, but may not be the 528x.
If so, what about the ReadyNAS 4312X's CPU ? I cannot find any information about it...
Thanks
Hi taiya
The ReadyNAS 4312X's CPU is Xeon E3-1245v5 not really sure if there's any upgrade available but it might just be possible.
RN526X's CPU is not soldered since it's an x86 Intel® D-1508, this one you might be able to upgrade with the right spec.
StephenB is right, doing upgrades outside of NETGEAR's Support will Void the warranty
Hope this helps!
Regards
