xua
Feb 08, 2017Aspirant
Can I use 8TB HDD
Question, I have several ReadyNASRNDX400E, and would like to use 8TB HDD (or larger), in particular, Seagate Archive HDD 8TB SATA 6GBps 128MB Cache SATA Hard Drive (ST8000AS0002) ...
vandermerwe
Feb 08, 2017Master
The archive disks aren't really suitable for NAS use, your write performance would be awful I think.
As far as size of disks goes, you could use 8 th disks, but bear in mind the 16 tb volume limit on 4.2.x firmware, this would mean you would need to factory default with the entire volume in place if the volume size was going to exceed 16 tb.
