peter2011
Dec 26, 2012Aspirant
Can I use drives fron one Pro in another Pro?
I've got some drives all set up and ready to go with double redundancy in a Pro, but now (for reasons I won't bore you with) I want to put the same drives in a different Pro (clearly, in the same orde...
chirpa
Dec 26, 2012Luminary
Yes that will work fine. Configuration is stored on the disks, so the other Pro would take on same hostname and such.
