peter2011
Dec 26, 2012Aspirant
Can I use drives fron one Pro in another Pro?
I've got some drives all set up and ready to go with double redundancy in a Pro, but now (for reasons I won't bore you with) I want to put the same drives in a different Pro (clearly, in the same orde...
mdgm-ntgr
Dec 26, 2012NETGEAR Employee Retired
peter2011 wrote:
Do I just put them cold in a new unit before ever switching on the unit, and then switch on?
Yes, see: http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
peter2011 wrote:
What if the new unit doesn't have the same Raidiator version, what will happen then?
That is a good point. Best to put a spare disk (must not be from your array) in the replacement NAS and check that the firmware is at least as new as the firmware on the old unit. You can update the firmware on the replacement unit, verify the update is successful, then power down, remove the spare disk and then migrate your array across.
Attempting to migrate an array running 4.2.16 (or later) to a system with 4.2.15 or older firmware on the flash is not a good idea. So checking the firmware is up to date in the replacement unit is strongly recommended.
