kamanwu
Dec 24, 2020Aspirant
Can I use WD Red Plus 6T/8T on my old NAS (Pro 4) which has been updated to OS6 (6.9.4)
Basing on this: https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List 4T is the max size. But I have updated the OS to OS6 (6.9.4). Can I use WD Red Plus 6T/8T ? Thanks a lot.
- Dec 24, 2020
4T is the max size.
The HCL for the legacy NAS hasn't been updated in several years - back in the days when 4 TB was the biggest drive on the market.
Yes. And you could even go larger - it can handle any enterprise or nas-purposed CMR sata disk on the market. I have two WD80EFAX in my own Pro-6 (along with four 3 TB drives).
Dec 24, 2020Guru - Experienced User
4T is the max size.
kamanwu
Dec 25, 2020Aspirant
Thanks for the reply.
For now, I have 3 disks (all 3T). I know I could add another 3T disk to get extra space. But I think it's kind of waste to buy a new 3T disk these days.
I plan to buy 2 new 8T disks to replace my THREE 3T disks. Laster I could get more space by adding extra 8T disks.
Do you know what's the easiest way to do this without copy all data out?
- kamanwuDec 25, 2020Aspirant
Forget to mention, my 3 old 3T disks are SMR, NOT CMR.
- StephenBDec 25, 2020Guru - Experienced User
kamanwu wrote:
I plan to buy 2 new 8T disks to replace my THREE 3T disks. Later I could get more space by adding extra 8T disks.
The only easy way is to upgrade two of the disks to 8 TB, and leave the third disk in place. 2x8+3TB would give you an 11 TB (~10 TiB) volume.
After you've done that, it is possible to shrink the volume and drop the 3 TB disk with SSH. But it is not that simple, and the folks here who've played with it strongly recommend backing up all the data first. Sandshark can give you more details if you want them.
StephenB wrote:
kamanwu wrote:I plan to buy 2 new 8T disks to replace my THREE 3T disks. Later I could get more space by adding extra 8T disks.
How can I do this? For now, 3 3TB disks give me 6TB space in total. If I pop up 1 3TB disk and put 1 8TB disk in, I will still have 6TB right? And if I pop up the 2nd 3TB disk out and put another 8 TB disk in, I will still have 6T right?
How to get 11TB (2*8 + 3 TB)?
If I buy 3 8TB disks, and replace 3 old 3TB disks one by one. After all done, I will have 6TB (same as before), and need do something to expand space to 16TB? or I will automatically have 16 TB space?
