davidr1
Dec 21, 2018Luminary
can not save configuration
OS 6.9.4, Linux 18.04, Firefox Quantum
Recently I decided to update my backed up settings configurations for the above drives.
I could not. I pressed Settings>Configuration Backup>Download config...
Dec 22, 2018Guru - Experienced User
Were you using admin, or some other account in the admin group?
Trying another browser is worth a try.
I'm not seeing this problem with 6.9.3 (using Chrome), so you could also try downgrading, saving the configuration, and then upgrading back to 6.9.4.
Sandshark
Dec 22, 2018Sensei
Have you enabled admin access through HTTP (rather than just HTTPS)? I find it odd that it's trying to access via Port 80, when it should be 443 for HTTPS. Maybe a bug when you have made that selection?
- davidr1Dec 22, 2018Luminary
Thanks all for the replies.
It worked before in firefox - I was just updating config files especially in light of a recent disk failue (2 year warranty left).
I always log in as a user. Have always had both http and https.
I tried Chrome today. The first time - no problem.
But the second time it came up Not a private connection. I went round this using Advanced and Allow.
Odd that I've never had these problems before.
Thanks for the Chrome suggestion - should have tried it myself.
- StephenBDec 23, 2018Guru - Experienced User
Chrome will do that, and there is no good workaround (other than what you did). It's because the NAS uses a self-signed certificate.
FWIW, Firefox downloads the configuration settings on my system (currently running 6.9.3).
- davidr1Dec 23, 2018Luminary
Thanks StephenB,
I'll recheck my security settings in Firefox.
Happy Christmas to all,
David
