hobbes487
Oct 05, 2015Guide
Pro Pioneer v4.2.27 - FrontView won't save configuration
I have a Pro Pioneer that I have had for just over 5 years without any issues major issues. Occasionally it would freeze up and I would just force it to shut off by holding the power button and it would boot back ok just fine. Yesterday I went to access data on it through the network on a windows machine and it was not accessible. I went to check FrontView and it came up so I new it wasn't frozen. In the standard file protocols everything was unchecked. I thought that was wierd, but just tried to re-enable all the protocols, but when I hit save all the check boxes cleared and nothing heppened. I tried to make some other configuration changes and nothing would actually save. I tried enabling/disabling plugins, but whenever I hit Save nothing happens. I even tried to reboot it through the Power menu, but nothing happens. I can shut it down properly using the power button on the NAS. I also noticed that the logs were completely clear which seemed strange.
Anyone have any idea what could have happened and how to fix it? I am able to log into it via SSH if that helps.
Thank you! I was able to use Tech Support mode to clean out all the Crashplan upgrade data. ForntView is now working and I can access my files again. Last remaining issue is that I can't access the ReadyNas via SSH so I can't upgrade the jre to the necessary version. Any pointers to figure out why SSH isn't working?
Log in with ssh, and enter
df . -h
df . -i
and post the output.
Also - are you running crashplan on the NAS?
Well, it looks like I can no longer log in via SSH. Only FrontView is working, but I can't save anything.
... and yes I am running Crashplan on it.
