armornone
Mar 05, 2013Aspirant
Can the Readynas Shutdown via UPS from cyberpower systems?
Hello. I was wondering if I purchased a UPS from cyberpower systems such as a CP685AVR with a USB interface, if the Readynas would be able to shut down when there is a power outage. I have ready o...
Mar 06, 2013Guru - Experienced User
Yes, Though the UPS USB is connected to the Duo v1, and monitored remotely by the NV+ v1.
armornone wrote: That is great news! Is your NV+ a version 1?
I don't recall if I ever had it directly connected to the NV+'s USB port. But If it works with the Duo, it should work with the NV+, the firmware is the same.
