westcamp
Oct 17, 2011Aspirant
Can we real-time sync 2 3200's or a 3200 and a 4200?
We currently have a ReadyNAS 3200, which is simply plugged into the network as used as File Storage. We are wanting to repurpose the ReadyNAS to become the primary storage for the messages for our em...
TeknoJnky
Oct 17, 2011Hero
the only supported two way sync is via the egnyte cloud product, but its not free.
there is a free trial if you install the addon, you can test it out and see if it works well with your particular situation.
if you only need one way sync, you could schedule rsync backups, this would likely be faster than ftp, but may have issues if files are inuse/modified during the backup
another alternative would be readynas replicate, which is sort of a cloud managed rsync + snapshots over readynas remote vpn. But replicate is not free either.
