dadoz_ts
Feb 05, 2017Aspirant
Cannot Access Admin Page ReadyNas 102 before Update firmware at 6.6.1
After updating the firmware with the automatic procedure to version 6.6.1, I access data from PCs, wishing I access via SSH but can not access most of the admin page. The problem seems to be the apa...
mdgm-ntgr
Feb 05, 2017NETGEAR Employee Retired
You'll need to provide more information than that?
What apache server error?
Did you try logging in using https i.e. to https://ip.address.of.nas/admin
Which services are you running?
Which apps do you have installed?
- dadoz_tsFeb 05, 2017Aspirant
No, with https://ip.address.of.nas/admin de Nas not respondig.
I do not remember all activated services, but everything worked before the upgrade.
Apache2 server respondig at #systemctl status apache2 whit:
"● apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset:enabled)
Drop-In: /lib/systemd/system/apache2.service.d
└─forking.conf
Active: failed (Result: exit-code) since Sat 2017-02-04 13:04:12 CET; 24h ago
process: 13828 ExecStart=/usr/sbin/apache2 $OPTIONS -k start (code=exited, status=1/FAILURE)
Process: 13758 ExecStartPre=/frontview/bin/fvapps (code=exited, status=0/SUCCESS)Feb 04 13:04:12 CattiviksNas systemd[1]: Starting The Apache HTTP Server...
Feb 04 13:04:12 CattiviksNas apache2[13828]: apache2: Syntax error on line 140 o
f /etc/apache2/apache2.conf: Syntax error on line 1 of /etc/apache2/mods-enabled
/auth_token.load: Cannot load /usr/lib/apache2/modules/mod_auth_token.so into se
rver: /usr/lib/apache2/modules/mod_auth_token.so: undefined symbol: ap_log_rerro
r
Feb 04 13:04:12 CattiviksNas systemd[1]: apache2.service: Control proces
s exited, code=exited status=1
Feb 04 13:04:12 CattiviksNas systemd[1]: Failed to start The Apache HTTP
Server.
Feb 04 13:04:12 CattiviksNas systemd[1]: apache2.service: Unit entered f
ailed state.
Feb 04 13:04:12 CattiviksNas systemd[1]: apache2.service: Triggering OnFailure=
dependencies.
Feb 04 13:04:12 CattiviksNas systemd[1]: apache2.service: Failed with re
sult 'exit-code'."I have this apps:
phpr6
smbplus
surveillance
- jlightyFeb 05, 2017Aspirant
hello,
I have exactly the same behavior after the upgrade to 6.6.1.
Hardware : Netgear RN102 / OS 6.6.1
what I did after having this error "/usr/lib/apache2/modules/mod_auth_token.so: undefined symbol: ap_log_rerror" :
apt-get autoremove => it removed apache2 package.
apt-get update / upgrade
Feb 05 15:31:52 nasalain rpc.mountd[3077]: Version 1.2.8 starting
Feb 05 15:31:52 nasalain systemd[1]: apache2-safe.service: Failed with result 'exit-code'.
Feb 05 15:31:52 nasalain systemd[1]: apache2-safe.service: Unit entered failed state.
Feb 05 15:31:52 nasalain systemd[1]: Failed to start The Apache HTTP Server (Safe Mode).
Feb 05 15:31:52 nasalain systemd[1]: apache2-safe.service: Control process exited, code=exited status=1
Feb 05 15:31:52 nasalain apache2[3029]: apache2: Syntax error on line 25 of /etc/frontview/apache/safe-mode.
conf: Syntax error on line 14 of /etc/frontview/apache/fv-admin.conf: Syntax error on line 1 of /etc/frontview/apache/Admin_Auth.conf: Syntax error on line 2 of /etc/frontview/apache/Auth.conf: Cannot load /usr/lib/apache2/modules/mod_privsep.sointo server: /usr/lib/apache2/modules/mod_privsep.so: cannot open shared object file: No such file or directory
root@nasalain:~# ls -l /usr/lib/apache2/modules/mod_privsep.so
ls: cannot access /usr/lib/apache2/modules/mod_privsep.so: No such file or directoryps -ef |grep http
daemon 3177 1 0 15:31 ? 00:00:00 /usr/sbin/upnphttpd
root 3267 3264 0 15:35 ? 00:00:00 /usr/lib/apt/methods/http
root 3268 3264 0 15:35 ? 00:00:00 /usr/lib/apt/methods/http
root 3269 3264 0 15:35 ? 00:00:00 /usr/lib/apt/methods/http
root 3270 3264 0 15:35 ? 00:00:00 /usr/lib/apt/methods/httproot@nasalain:~# netstat -na |egrep '80|443'
udp6 0 0 :::34430 :::*
unix 2 [ ] DGRAM 6280 /var/lib/samba/private/msg.sock/2133
unix 3 [ ] STREAM CONNECTED 4806
unix 3 [ ] STREAM CONNECTED 4807 /run/systemd/journal/stdoutConclusion : nothing is listening on 80 neither 443
If someone has a working web interface on a RN102, could you tell me if the module mod_privsep.so exists ?
thanks for your help
- aalexandrebetaFeb 05, 2017Master
I had that issue solved by the support!
In 10 minutes the issue was solved!
- mdgm-ntgrFeb 05, 2017NETGEAR Employee Retired
dadoz_ts are those apps up to date?
I do not know and I can not verify no longer having access ..
However, these are the 3 installed apps, but are currently not used, neither before nor after the upgrade.
