chrisqn
May 18, 2016Tutor
Cannot access share on ReadyNAS Duo
Hi, I have a ReadyNAS Duo which has a few shares that run with "Allow guest access". Now i want to have a share that is protected and only accessable by my PC (Windows 10) but i cannot access the...
- May 18, 2016
Hi chrisqn,
Try the steps below:
1. Create a specific user login under 'Security tab'.
2. Change the default access of the said share from Read/Write to 'Disabled'.
3. Tick write-enabled users and enter your user login then hit apply.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
BrianL2
May 18, 2016NETGEAR Employee Retired
Hi chrisqn,
Hope this helps!
Kind regards,
BrianL
