chrisqn
May 18, 2016Tutor
Cannot access share on ReadyNAS Duo
Hi, I have a ReadyNAS Duo which has a few shares that run with "Allow guest access". Now i want to have a share that is protected and only accessable by my PC (Windows 10) but i cannot access the...
- May 18, 2016
Hi chrisqn,
Try the steps below:
1. Create a specific user login under 'Security tab'.
2. Change the default access of the said share from Read/Write to 'Disabled'.
3. Tick write-enabled users and enter your user login then hit apply.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
BrianL2
May 24, 2016NETGEAR Employee Retired
Hi chrisqn,
Just following up if you have tried the steps I posted in my previous reply.
Kind regards,
BrianL
chrisqn
May 26, 2016Tutor
Hi BrianL,
thank you for your help. I tried the steps you posted many times before I posted my question but it never worked. After I got your answer I tried it again an it still did not work. In a different post I read that it could be a problem if network drives are mapped to the ReadyNAS Share so i deleted all my network drives on the computer and voilà it worked. Dont know why network shares should be a problem but it seams to be the solution for my problem.
best regards,
Chris
