brandtz
Jan 02, 2014Aspirant
Cannot Browse NAS from XP?
Hi, I have seen and read the other similar topics but cant solve the problem...I am using RAIDar 4.3.8 and can see the NAS and its IP 192.168.0.15 But the "browse" button is grey and cant be presse...
Jan 03, 2014Guru - Experienced User
Yes, this post indicates it is a v1 (and back then was running 4.1.6). viewtopic.php?f=24&t=63055&p=353259#p353259
Did you ever update it?
Linux Reader should let you access the data on disk 1, but will not work on disk 2. Be sure the NAS is powered down when you remove the drive (and stays powered down until you reinsert it).
