CarlEdman
Jan 01, 2019Luminary
Cannot Copy Files Larger Than 2 GByte to ReadyNAS
I'm running the latest ReadyNAS 6.9.4hotfix1 on my ReadyNAS with more than 3.5 TByte free and a Windows 10 Pro x64 workstation and have for many years (with whatever the latest official version was a...
- Retired_MemberJan 01, 2019
That sounds weird, CarlEdman. What happens in case you use the admin page in a browser on your windows workstation to pull (upload) one of the concerned files to the nas?
Kind regards
CarlEdman
Jan 02, 2019Luminary
Thanks for the suggestion, Retired_Member! I didn't even know you could do that.
The result: It actually worked (albeit at a much lower transfer rate of about 22 MByte/sec), solving my immediate problem.
But I still wonder why the underlying issue occurs.
Retired_Member
Jan 02, 2019I would also like to know, CarlEdman, but could only guess.
If you do not need IPv6 and have it enabled in the network configuration of the nas, please disable it there and give it another try.
Kind regards
