Tobbegutt
Sep 05, 2019Aspirant
Readynas duo larger hdds
I just recently bought a readynas duo as i alread6 have a readynas ultra home.
This one has 2 hdd slots.
I have all my nas set up as 0 in raid as i need most storage and arent really worried about loosing any storaged files.
This unit came with 2x 750gb hdds and i took them out and stuck in 1x 3000gb hdd and 1x 4000gb hdd. But one drive only show 1600gb and the other 750gb.
It doesn't make any sense. I have used both of these hdd in my ultra and i have tried resetting everything 4 times already. Tried hotswapping and disk quota and files check etc.
But it seems i cannot find out what the f. This problem is.
Yeah i know its a old unit, but its upgraded with 1000mb ram and surely it should be able to read a simple harddrive and get the storage available correct??
Thank you for all suggestions.
Tobbegutt wrote:
well, on the underside is says rnd2100 V2
The other labels can be confusing - that's why I posted the way to distinguish the models. What you have is hardware revision 2 of a Duo v1 NAS.
Tobbegutt wrote:But is there no unofficial software or firmware anywhere?
Its strange to have something like this and it cant read larger hdds,,
The chipset / hardware architecture goes back to ~2005. There isn't any way around the 2 TB limitation (firmware, software, what have you). You'll also find it can't access USB drives that are bigger than 2 TB.
So you are limited to 2 TB of RAID-2 or 4 TB total of jbod or RAID-0 (2x2TB drives).
I think you purchased a used Duo v1. That would
- say Duo on the front chassis
- run 4.1.x firmware
A Duo v2 would
- say Duo v2 on the front chassis
- run 5.3.x firmware
The Duo v1 is an old design that was discontinued in 2011. It never supported GPT formatted drives - so the max size you can use is 2 TB. This has nothing to do with the amount of memory, and there is no way to fix it.
So you'll either need to use 2 TB drives or you'll need to return the NAS to the seller.
- TobbeguttAspirant
but there doesnt say V2 on the front.
I cant return it to sender as i bought it used obviolsy and he sent it to me so to send it back it will have costed me more than the NAS itself. So ill guess if i cant update it in any way i just resell it to someone else just as stupid and unlucky as my self.
