AUSAL
May 08, 2016Aspirant
Cannot register Photo II
I am unable to get the photo add-on (Photo II) set up and functional in my EasyNAS (RND2000-200AJS) Duo V2
The obstacle seems to be -
Status: Not registered (Error msg reads "Server registration process failed. This could be either a bad hostname or communication error" )
1. My router is set up with UPnP. I expect port to be correctly assigned and no apparent reason why this is not functional.
2. Host name availability always fails validation test.
The version of Photo II is 1.0.5. I cannot verify if this is latest, but "check for latest update" does not make any change
Seems like i am tripping up on something simple.
Any assistance wold be appreciated
Found my answer at https://community.netgear.com/t5/Current-NETGEAR-and-Partners/Status-Not-Registered/m-p/836880#M656
(How do i close the topic :)
- AUSALAspirant
- BrianL2NETGEAR Employee Retired
Hi AUSAL,
Welcome to the community!
We're glad that you are able to find the solution to your problem. If in case you still have question/s or other problem/s you may create a new thread in the community. Lastly, you may mark this thread closed by clicking the "Accept as Solution" button in one of the response/s that you received.
Kind regards,
BrianL
NETGEAR Community Team
