RcR
Sep 19, 2015Tutor
Can't access admin panel (ReadyNAS 102)
After turn on my NAS gets IP address 192.168.2.25 I can ping it from my PC. Power led blinks constantly after power up, I can turn it off only by unpluging power cord. I can't access admin panel by b...
- Sep 19, 2015
Hello RcR,
Welcome to the community!
The OS and data are saved to the disk that is inserted to the ReadyNAS chassis. Without any disks, it is useless, you will not be able to access its admin page. SSH is also disabled by default so if you want to access it via SSH, you need to get to the admin page first then enable it from there. The Telnet access is designed for engineering and L3 support.
JennC
Sep 19, 2015NETGEAR Employee Retired
Hello RcR,
RcR
Sep 19, 2015Tutor
Looks like whole problem is because of my lack of knowledge of how it works (your message made it all clear) and a fact that I should leave ReadyNas 102 in box before new drives arrive... now it is clear that no matter what I will not initiate my old drives (for now my PC wiith server software has to stay on as a teporary NAS :) ). Thanks for Your time and patience (both StephenB and JennC). Looks like my case should be fully solved on tuesday. Best regards.
