cmav
Feb 22, 2022Aspirant
Cant access drive via IP address
Hi, I have several shares setup on my Nas ultra 2. The IP address of my nas is 192.168.68.103 and the name of the name is Strider (see attached). I have smb1.0 enabled fyi. After mappin...
Feb 22, 2022Guru - Experienced User
cmav wrote:
After mapping my shares succesfully to "\\192.168.68.103\Movies" after a few days and restarts I can no longer access my mapped drive in explorer via "\\192.168.68.103\Movies"
However I can still access it from "\\1strider\Movies"
Please advise why this might stop working from my IP.
This could be a credentials issue. 1strider and 192.168.68.103 are treated as two different machines as far as Windows is concerned.
When you say "restarts" - did you restart the PC or the NAS? Try restarting the PC if you haven't done that.
If restarting the PC doesn't work, then open the Windows Credential Manager, and delete any credentials you see for 192.168.68.103. Then try \\192.168.68.103\Movies again.
- cmavFeb 23, 2022Aspirant
Thanks for the qick reply.
I have restarted both PC and NAS in that time.
I have checked the Windows Credtntials manager and there is no entry for 192.168.68.103.
- StephenBFeb 23, 2022Guru - Experienced User
Is there one for 1strider???
Maybe try using CMD as a test. Enter
net use * /delete /y net use t: \\192.168.68.103\Movies /user:admin nas-admin-password
using the real NAS admin password of course. Be careful on the two different slash directions.
The first command terminates any open SMB sessions. The second attempts to mount the share as drive letter T using the NAS admin credentials.
- SandsharkFeb 23, 2022Sensei
Also, by what means are you ensuring that the NAS always has the same IP address?
