cmav
Feb 22, 2022Aspirant
Cant access drive via IP address
Hi, I have several shares setup on my Nas ultra 2. The IP address of my nas is 192.168.68.103 and the name of the name is Strider (see attached). I have smb1.0 enabled fyi. After mappin...
cmav
Feb 23, 2022Aspirant
Thanks for the qick reply.
I have restarted both PC and NAS in that time.
I have checked the Windows Credtntials manager and there is no entry for 192.168.68.103.
Feb 23, 2022Guru - Experienced User
Is there one for 1strider???
Maybe try using CMD as a test. Enter
net use * /delete /y net use t: \\192.168.68.103\Movies /user:admin nas-admin-password
using the real NAS admin password of course. Be careful on the two different slash directions.
The first command terminates any open SMB sessions. The second attempts to mount the share as drive letter T using the NAS admin credentials.
- SandsharkFeb 23, 2022Sensei
Also, by what means are you ensuring that the NAS always has the same IP address?
