stefanom62
Dec 16, 2020Aspirant
Can't change Raid type after factory reset, nothing happens in the 10 minutes windows
Hello, I just successfully upgraded my old ReadyNas Ultra 2 to OS 6 and now I have firmware 6.10.3. So far so good, I had a few glitches but now it works fine. My only BIG issue is that I can't conf...
- Dec 16, 2020
stefanom62 wrote:
I understand that there should be a pop up or a button should appear in my Raidar (6.5.0) window in the first 10 minutes after factory rebooting but nothing happens
No, that's not how it's done with OS 6. 5.x and earlier firmware required a factory reset to switch to FlexRAID (with the 10 minute window). 6.x systems don't use that - you can switch from XRAID to FlexRAID without doing a reset (and in many cases you can switch back to XRAID from FlexRAID).
In your case, you
- disable XRAID by clicking on the XRAID control on the volume tab. (XRAID is enabled if the control has a green stripe).
- destroy the RAID-1 volume by clicking on the volume settings wheel (and choosing destroy).
- select the disk(s) from the graphic in the center of the volume settings wheel, and create a new volume with the desired RAID mode.
You don't need to wait for the RAID sync to complete - you can take these steps while the volume is being built.
More information is in the software manual, and in the FlexRAID optimization guide:
- https://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf
- https://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_FlexRAID_Optimization_Guide.pdf
You'll find that in OS-6, FlexRAID gives you more control over the RAID modes than older ReadyNAS, but is also more complicated.
Dec 16, 2020Guru - Experienced User
In your case, you
stefanom62
Oh my, thank you, you totally made my day!
