Nospam555's avatar
Nospam555
Can't connect to ReadyNAS 102
After several years of no problems for backups, I can't find my ReadyNAS 102 from any computer. Under Devices and Printers it shows as grayed out. I downloaded the latest version of RAIDR and it can't find the drive. It's set at default, so dynamic IP, no apps used, it's only used to store backup images. All lights on the front are on solid (not blinking).
  • You can migrate your disks to the RN424.
    If you have apps installed, you might run into some trouble since many are x86 or arm specific - but the system should come up anyway.
  • StephenB's avatar
    -Does your router show the NAS as an attached device?
    -Were email notifications turned on, and if so did you receive any shortly before the problem began?
    -What is the status of the ethernet led on the back?
    -Do you know how full the volume is?
    You might need to forcibly shut down (try holding down the power switch for 5 seconds or so, or just pull the plug).  Either way, there is always some risk of data loss when you do this - but if you can't get access, you need to take that risk.
    • Nospam555's avatar
      Nospam555
      No, the router (Netgear R7800) does not show the ReadyNAS in the Attached Devices tab.
      E-mail notifications were turned on, but I received no e-mail before this occurred. I only see one test message 3 years ago, and one rebooting message from a year and a half ago.
      I don't see an ethernet LED on the back. It's not that I see it not lit, I just don't see one.
      The volume was probably about about 80-85% full.
      I have forcibly shut down the router twice, and also cut power through the UPS to the system (main PC, Router, monitor, cable modem); no change after rebooting.
      Thanks.
      • StephenB's avatar
        There are leds there built into the connector that normally show network status.  See page 19 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
        Try powering down the NAS, and then removing the disk drive(s) - labeling by slot so you can return them to the right position.
        Then power up the NAS and see if you any network activity.  RAIDar should show a "no disk status".  If that fails, try a different switch port on the router, and perhaps also different cable.
        If you don't still see any LED activity on the network, then you likely have a failed NIC.  It's not repairable, it is covered by the 3-year warranty.  You can check your warranty status at my.netgear.com (and if your product wasn't registered, you should do so).  You should also upload proof of purchase if you haven't already done so.  Then if you are still covered by the hardware warranty you can use the "return my defective product" link to create a support case.
ProSupport for Business
