Readybear
Jan 06, 2023Aspirant
Can't connect to the Frontview of a Readynas Ultra 4
My Readynas lost a drive a while back so I'm trying to not boot it up too often until I have a replacement drive. The firmware is possibly the latest version and I don't want to check again until I h...
Jan 07, 2023Guru - Experienced User
Readybear wrote:
Different browsers give different errors. Chrome says ERR_CONNECTION_RESET. I'm never able to reach the login page.
Are you running 4.2.x firmware or have you converted the NAS to OS-6?
FWIW, RAIDar should be telling you the firmware. Current versions are
- 4.2.31
- 6.10.8 (if you converted).
Readybear wrote:
On my windows machine on the network page the Readynas is listed as a media device but not as computer so I can browse my files.
If you are using 4.2.x firmware, have you checked that the PC has the SMB 1/CIFS client enabled? Do this by going into "turn windows features on or off".
Does entering \\nas-ip-address in the File Explorer Address bar give you access from Explorer? (using the real NAS IP address of course).
